02-18-2009 11:30 AM - edited 03-15-2019 04:19 PM
Hi All,
I want to install 7.0 CUCM and get license file for new server. I don't want to upgrade, only fresh installation. How can I retrieve license file from 4.0?
thanks
Alex
Solved! Go to Solution.
02-18-2009 11:46 AM
without DMA you can't do it yourself, get in touch with licensing@cisco.com for this
java
if this helps, please rate
02-18-2009 11:46 AM
java
