Migrate some information from a CUCM 4.1 to 6.1
can i mgrate the following from a existing CUCM 4.1 cluster to existing CUCM 6.1 :
- Personnal adress book
- Forwad configuration of IP Phones (noan, busy)
- some translation that permit to call without entering the complete phone number but just 4 digits for example.
Mohamed
1 REPLY
Hall of Fame Super Red
Re: Migrate some information from a CUCM 4.1 to 6.1
Hi again Mohamed,
You can use the BAT Export from CUCM 4.x and then Import on CCM 6.x but the .csv files will need to be tweaked. The look and feel of BAT on 6.x versions is a little different so you would have to experiment with what fields need to change before the actual Import is done. This can be used to migrate the Device FNA/Busy info. PAB and Translation rules will need to be re-configured :)
Cisco Unified Communications Manager Bulk Administration Guide
Inserting Phones
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/7_0_1/t03inph.html
Hope this helps!
Rob
127
