Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
migrating callmgr 3.3 data to callmgr 6.1
I have a customer getting upgrading a 4.1 cluster to new 6.1 cluster, with new servers.
Part of project is to remove an existing 3.3 cluster and migrate devices into the new 6.1 cluster.
The data migration tool can not be used so I'm looking at running route plan report and converting it to a BAT file which can then be imported into the 6.1 callmgr.
Has anyone done this and what would you recommend as best way to do it.
Site has a few hundred phones.
thanks
Rob
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: migrating callmgr 3.3 data to callmgr 6.1
Hi Rob,
Have you thought of using the BAT Export? (all device details)
This may take some testing to find the exact method to use. I would try this on only one or two test phones for starters. Try an Export of these test phones into a .csv file then you will have to cut/paste these details to match the new BAT format in CCM 6.x. This seems like a reasonable work-around.
Take the .csv file you got from the Export and change the DN's as required. Then use this new import file and then do a Phones/Users Import.
Bulk Administration Tool User Guide, Release 5.1(4)
Working with the Export Utility
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a00803f4f29.html#wp1066964
Hope this helps!
Rob
Hi Rob,
From this doc;
Hope this helps!
Rob
Rob
Sounds good.
I'll give it a try
thanks
Rob
117
