Silver
Migrating from SCCP to MGCP-Help needed
I need to remove SCCP from a voice gateway 224 and reconfigure it as MGCP. I`ve deleted references to SCCP but the voice port are still SCCP . What is the best way to remove SCCP and so re-configure the GW as MGCP. Is it easier to erase Start up ?
thanks
1 REPLY
Silver
Re: Migrating from SCCP to MGCP-Help needed
For MGCP, the MGCDefault.cnf and MGC.cnf files are downloaded when a phone is reset. This file contains the image_version parameter that tells the phone which image it should be running. If the image load differs from the one that is currently loaded on the phone, the phone contacts the TFTP server to upgrade to the new image
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/mgcp/firmware/matrix/frmwrup.html
127
