08-30-2012 12:11 PM - edited 03-16-2019 12:57 PM
We have uploaded mac info in new call manager and configured option 150 scope from old call manager to new cucm.
When we give reset on all phones, phones are registering back to old call manager.
08-30-2012 12:13 PM
I need to switch a number of remote phones from their existing Callmanager server onto a new one.
Changed option 150 to point to the new CM, then doing a remote reset of the phones makes none of the phones to be register onto the new CM. all phones continue to use their old settings for TFTP
08-30-2012 12:54 PM
Are the phones picking up the new TFTP address?
Chris
08-30-2012 12:58 PM
NO !!!! All the phones are registered back with old call manager
08-30-2012 01:04 PM
Try disconnecting the phone or shut and unshut the phone to force it to renew DHCP.
Also, look at the phone console log by browsing the IP address of the phone.
Chris
08-30-2012 01:09 PM
Shut and unshut under interface of the switch in where phone connected, doesnt work out.
we have deleted all phone mac address under address lease and refreshed. .. .nothing happens...
phones goes back to old call manager again.
08-30-2012 01:11 PM
Do you have any phones registered to the new CUCM? Have you validated that TFTP on it work?
Are you using Auto registration or have the phone defined?
What do you see in the console log?
Chris
08-30-2012 01:20 PM
Yes, some remote phones are registered to new CUCM but it is different device pool.
We trying to move other remote phones located in other office in this new CUCM and it is other device pool.
phone defined , we are not using auto reg...
