Migration CCM4.2 to CCM8 : how about license and data migration?
iantra123
Level 3
Level 3
We plan to migrate a customer from CCM4.2 to CCM8.
Question : How about the license migration from 4.2 to version 8?
Can you give any link about lincensing migration, and migration from v4 to v8?
best regards,
Antra
Jaime Valencia
There is no direct migration path, you need to go to a 6.X or 7.X before going to 8.X
Table 4     Supported Cisco Unified Communications Manager Upgrades for  Release 8.0(x)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp184796
If you use DMA and then the Linux to Linux migration all your licenses will be migrated in the process, otherwise if you do a fresh install you need to reach licensing (licensing@cisco.com) so they can migrate the licenses.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
