05-24-2010 10:17 PM - edited 03-15-2019 10:55 PM
I like to have my users dial from their Cisco phones as they do from their cell phones. This means 10 digit dialing for all domestic calls and 011 in front of international calls. I don't want or think I need to use the old dial "9" to get a line deal. So I am thinking of creating only two dial peers like this:
dial-peer voice 1000 voip
description 411, 911
destination pattern ...
dial-peer voice 1001 voip
description domestic 10 digit
destination pattern ..........
dial-peer voice 1002 voip
description International
destination pattern 011T
Is there some reason why this shouldn't work? What are the pros and cons?
Diego
05-25-2010 03:26 AM
Hi diego,
This wouldn't work. Because as soon as someone dial 3 digit, no matter what they were suppose to dial, it will match dial-peer 1000 and send the call. User wont have option to dial any further digit. You could have use
destination pattern [49]11
destination pattern [2-9].........
Hope this helps
- abu
05-25-2010 04:52 AM
Good point! and now I also see another problem. 2xx numbers are local extensions and 3xx are extensions located on a remote CME box. How would I work those in to this config?
Diego
