Community Member
minimum hardware requirement for cucm
I have dual core 1.7 ghz processor and windows 7 and ram 2.5 gb an 500 gb harddisk .Will cucm 8.0 install on vmware machine on such configuration.
pankaj sharma
1 REPLY
Blue
Re: minimum hardware requirement for cucm
Minimum 2.4 GHz CPU is required.
If you are following all the requrement in below link you can have CUCM installed in third party hardware also.
http://docwiki.cisco.com/wiki/Specification-Based_Hardware_Support
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
394
