Community Member
Minimum length of FAC
What is the minimum length I can define a Force authorization code?
regards
1 ACCEPTED SOLUTION
Re: Minimum length of FAC
This is info is easily found if you look at the admin guides:
Enter a unique authorization code that is no more than 16 digits. The user enters this code when the user places a call through a FAC-enabled route pattern.
Minimum 1 - Maximum 16
And you cannot define a minimum number of digits for the FAC
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
149
