Minimum message duration on CUE
We are getting complaints from users that they are not receiving all the voicemails that are left for them. In testing, we discovered that the minimum duration of a message in CUE is 3 seconds. We are discussing the possibility that some of our test messages are less than 3 seconds and are therefore being dropped.
It seems strange that the minimum is set to 3 seconds. Can someone confirm this, and can you also tell me if it can be changed? A message like "test message 1" can easily be less than 3 seconds...
1 REPLY
Re: Minimum message duration on CUE
I have a client with the same issue. Did you find a resolution to this?
91
