Community Member
Minimum PIN length in CCM User?
Hello, is there a way to restrict users to enter a minimum number of digits in CCM User? We noticed by default that any number (even 1!) is acceptable.
Silver
Re: Minimum PIN length in CCM User?
You can change the minimum password length in the DC Directory.
Start > Programs > DC Directory Administrator > Login > Scroll down to
Directory > cisco.com > CCN > right click system Profile > properties > CCM Configuration. Here you can modify the minimum length of PIN.
DC Directory: Modify the Default User PIN and Password Length:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00805ca029.shtml
Community Member
Hi there, thanks for that - do you know where the parameter is in version 5.0+ (specifically 6)?
153
