Community Member
MinSE parameter of cucm
Hi, anyone tried to change the MinSE value in cucm? The default value is 1800. But the nice recorder setting is 90 and they requested we configure the same value in cucm.
Will it have any impact on other services using sip?
The Min-SE value states that
The Min-SE value states that this is the minimum value allowed for the interval, so setting it to a value of 90 would mean a minimum of 90 seconds but values higher than that are also supported.
Yes, this will affect the way the CUCM behaves in all of its calls. I have seen many customers with NICE integrated and not reporting issues with calls.
You need to see if any other applications needs a higher minimum session timer value. If the Min-SE field is lesser than their expected value, then they will send a 422 back to the CUCM.
Community Member
Thanks for the info...if I
Thanks for the info...if I have several sip trunks with different services, it will be very difficult to comply with each of them...l..
Here's one of the issues that
Here's one of the issues that were faced with the Min-SE timer.
