Community Member
Minutes Based Calling
Hi All,
I was searching any option from Cisco UC that can offer minutes-based calling options for a partition OR extension.
Any body knows how to acheive this in Cisco UC, or using any other VAS solution
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Minutes Based Calling
And I have replied, thanks.
Can you please explain a bit further.
Time of Day routing maybe what your looking for.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a7bc96.shtml
HTH, Please rate if so.
Justin
Community Member
Hi there,
No its not TOD (Time of day routing).
Its like i will select a bucket of 60 minutes (lets say) & assign it to any partition OR DN. then after using 60 minutes in all the DN will not able to place any calls.
Its like prepaid billing. IS Cisco CUCM is carrier class PBX, or it is intended only for enterprises???
Community Member
I got question regarding the same issue and I replied there no way
but if there is any way to do this i will be happy
You you are interested in custom script developed for the purpose, you can contact me at the address present in my profile.
Community Member
yes,i already sent email to ur profile email id
Without revealing trade secrets/code details I'd be interested to hear a high-level description of the solution, if possible.
Admin sets parameters like who can call where and for how long using which line.
But is not released yet, because nobody so far has put his money where the mouth is.
308
