Community Member
Missed call information with Expansion module
We have two admins with an expansion module that share the same DNs of executives in the office. When someone calls an executive and they don't answer the admins see a missed call. One of the admins can go to Directories | missed calls and see the call detail From "phone number" for "Executive A" but the other admin only sees "From "Phone number" and not who it was intended for so she gets confused if the call was intended for her or someone else. I looked at both phones and don't see any differences.
Hall of Fame Super Red
Re: Missed call information with Expansion module
Hi Chris,
Is it possible that these are two different IP Phone models? Like perhaps a 7960 and a 7961? The older models like the 7960 do not show the detail that the 3rd generation models like the 7961 do.
Just a thought,
Rob
Community Member
I noticed the two phones are different images (both are 7961G).
I tried upgrading the phone that is not working but it keeps the same image.
This phone works
App Load ID Jar41sccp.8-2-1ES5.sbn
Boot Load ID 7961G_64-02070631Amd64megRel.bin
Version SCCP41.8-2-1ES5S
Expansion Module 1 S00105000300
This phone does not work
App Load ID Jar41.2-9-2-26.sbn
Version 7.0(3.0S)
Hi Chris,
Well, I guess that's where the problem lies. Whta we need to find out is why the second phone won't upgrade to the newer firmware? If you watch the phone when it boots up can you see where this upgrade fails by the message on the screen of the phone? If not perhaps you can setup a sniffer to get some traces of the boot/tftp sequence.
Rob
Community Member
Thanks Rob. I copied TFTP locally to that phone and I got it upgraded. I'm just waiting for a response from the user, but I'm sure it will be working now. Thanks.
Hi Chris,
Nice work! I'm quite sure that this will resolve the issue.
Cheers!
Rob
199
