Missed call Report
Hii,
In CCM 5.1 , can we generate the missed call reportin CDR? if possible plzz tell me the procedure
plz help me
thanks & Regards
Soma
Re: Missed call Report
hii,
thanks for reply. those are the very good document. but I didn't get any information about that How to generate the miss called in CDR Report . please sent me the procedure for missed call configuration in CDR,
Thanks & Regards
Soma
missed calls should show up as 0 duration if you have that parameter enabled, since they were never connected they should show up that way
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Dear,
Thanks for reply.that means u telling about
'CDR Log calls with zero duration flag' should be enable? I already enabled this parameter , but still now its not generated any zero duration calls in CDR Report.
So plz suggest me.
thanks & regards
Soma
hi
is this allready solved .. can you perhaps share the solution .. thanks in advanced
223
