Community Member
Missed Calls Date in CDR
We need to generate a missed calls report from CCM 4.2
CDR flags are enabled and "Log Calls with Zero Duration" flag is also enabled.
The problem is that all missed calls are logged in the CDR with a Date of "0". The "dateTimeConnect" is always Zero.
This way, it is not possible to get the date and time of individual missed calls.
Any suggestions?
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Super Bronze
Re: Missed Calls Date in CDR
Surely you would expect 'datetimeconnect' to be 0, as there was no connection?
There are other fields - if I recall correctly there's a 'datetimeorigination' that will probably be non-zero.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Happy to help...
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
Aaron
Super Bronze
Aaron
Community Member
Yep, thanks Aaron. That did it.
BR
Super Bronze
Happy to help...
Aaron
550
