Community Member
Missed Calls not displayed on ip phones
Dear All,
for unknown reason some of the ip phones stop displaying Missed Calls and please help on that
I'm using communications manager 9.0
best regards
Kennedy
> is that problem only with missed call? how about received & dialed call lists?
> do the affected phones show the date/time correctly?
> can you check and compare the firmware of working & nonworking phones?
//Suresh Please rate all the useful posts.
Community Member
thanks for the reply
the problem is with Missed calls only
both working and not working phones disply the same time
both working and not working phones run SCCP 9.3.1.3
could you please verify if the '' is checked under directory number configuration of those affected phones?
Community Member
it's already checked
Purple
Hi Kennedy,
Just look into the bug
7962 phone not able to record missed and received call in call history
CSCud19308
Symptom:
7962 phone not able to record missed call in call history
Conditions:
phone is running version SCCP42.9-3-1-1S on CUCM 9.0
there is no call record in the call history. other phone call this phone and this phone don't answer. this phone don't have any record of the missed call in call history.
Workaround:
no
regds,
aman
318
