Missed calls notification
scotteturner
Is there a way to either turn off the missed calls notification on a phone or have it only display for missed calls a the primary line? Users have several shared lines and it becomes confussing when they see multiple missed calls and they don't know which line it was on.
Thanks for your help!
Scott
5 Replies 5
mwild
I think it only displays for the primary line?
No it is displaying for all lines, not just the primary.
I have several customers with the same issue.
Would be nice if i could configure missed call notification on a per line and per phone or user device profile basis.
Like Ring/Flash only settings etc
Hi Keith,
This is a bit of a pain for our "Shared Line" users as well :( One thing that does mitigate this somewhat is that when scrolling through the "Missed Calls" list, when a number in the list is highlighted you will see;
On xxxx (where xxxx is the actual number that the call came in on, this is breifly displayed right before the Time and Date info)
So,if the 7961 had the following lines;
Line 1 - aaaa
Line 2 - wwww (Shared)
Line 3 - xxxx (Shared)
Line 4 - cccc (Shared)
You could identify when the Missed Call was for aaaa,wwww,xxxx or cccc by looking at the info;
Missed Call from xxx-yyy-ssss
On - cccc (The call was intended for cccc)
Today at 6:53AM
It took awhile for our users to get used to looking at this info to see which line the
"Missed Call" was really intended for.
Now,this is not so much of an issue.
Hope this helps!
Rob
Hi Rob,
Thanks for that i'll pass that info on to the customer, as he is getting quite a few complaints from user. We added group shared lines to over 150 users. i hope the developers consider adding a feature like no missed call notification in a future release.
Keith
