Missing commands for Telephony Service
For some reason I am missing a lot of features when using the Voice side of my router. There are more commands missing than what I have listed. I listed a couple below CUCME 4.3 ((C3745-ADVENTERPRISEK9-M), Version 12.4(25)
1. I have a 7906 and I dont see the option for the firmware load. I used the load 7905 with the 7906 firmware but now the 7906 doesn't work correctly.
How can I see the options to load different firmware?
<loadInformation20000 model="IP Phone 7905">SCCP11.8-3-3S</loadInformation20000>
RT_3745(config-telephony)#load ?
12SP Select the firmware load file for 12SP+ and 30VIP phones
7902 Select the firmware load file for 7902
7905 Select the firmware load file for 7905
7910 Select the firmware load file for Telecaster 7910 phones
7912 Select the firmware load file for 7912
7914 Select the firmware load file for sidecar 7914
7920 Select the firmware load file for 7920
7935 Select the firmware load file for 7935 Conference Station
7936 Select the firmware load file for 7936
7960-7940 Select the firmware load file for Telecaster 7960 & 7940 phones
7970 Select the firmware load file for 7970
7971 Select the firmware load file for 7971
ATA Select the firmware load file for ATA
2. I dont see the option for auto-reg-ephone
RT_3745(config-telephony)#auto?
auto
3. I also get this error when trying to create cnf-files. This happened after I upgraded my router to 12.4(25). I can't delete them either. I switched back and the error went away. Any suggestions on how to change IOS versions without getting this error?
%Error deleting flash:SEPDEFAULT.cnf (No such file or directory)
%Error deleting flash:XMLDefault.cnf.xml (No such file or directory)
RT_3745#cd system:
RT_3745#delete /force XMLDefault.cnf.xml
%Error deleting system:XMLDefault.cnf.xml (Invalid argument)
RT_3745#
RT_3745(config-telephony)#no create cn
RT_3745(config-telephony)#no create cnf-files
CNF files deleted
RT_3745(config-telephony)#cre
RT_3745(config-telephony)#create cn
RT_3745(config-telephony)#create cnf-files
Creating CNF files
1 ACCEPTED SOLUTION
Re: Missing commands for Telephony Service
Incorrect. You're not on CME 4.3, you're on an older CME version.
The most recent version is 12.4(15)T10
Try this and you should be fine.
-nick
Hall of Fame Super Gold
Really upgrade to lastest T or YB and your problems should go away.
Downgraded to 12.4(6)T. Create CNF problems went away but the other commands are still unavailable. 12.4(25) is the newest IOS available for the 3745
-nick
407
