Missing Line Appearances on CUPS
I have the following error reported on the CUPS System Dashboard.
How can I troubleshoot this?
I am assuming that this is related to my impossibility to see status changes on CUPC when a user has an on going call.
I also see that the user device´s status in CUPS Presence Viewer has a question mark on it.
Ariel
Everyone's tags (4)
1 ACCEPTED SOLUTION
Super Bronze
Re: Missing Line Appearances on CUPS
What this means is that either:
1) You may not have properly configured your SIP PUBLISH trunk.
2) If you think you have, then you probably haven't configured the Line Appearance Associations. This isn't the association of a device to a user through 'End Users' in CCM, but is the association of a specific line appearance (i.e. device/line pair) to the user.
To do this for a single user, browse to the user's phone or Device Profile (if using EM). Click their primary line, then scroll down to the bottom. You can add the user there as an 'associated user'. Save that and reset, and it should resolve the issue for the test user.
To do this in bulk, there is a facility in BAT:
https://supportforums.cisco.com/message/3043177#3043177
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Super Bronze
Aaron
Aaron,
  It was as you stated on item 2). I did as you detailed and it worked,
  Thanks. Post rated!
Ariel
Super Bronze
Good stuff.. thanks.
4655
