Missing "RmLstC" softkey
The manual for the 7940 phone indicates that when the phone is used to initiate a conference call, the intiator should be able to drop the last call added by using the RmLstC softkey:
"You can drop the last party added by pressing the RmLstC softkey."
However, our 7940 phones do not show that softkey during a conference call. The "EndCall" softkey disconnects all parties.
The template looks like this:
ephone-template 1
softkeys idle Newcall Redial Dnd Cfwdall Pickup
softkeys seized Endcall Redial Cfwdall Pickup Gpickup
softkeys connected Trnsfer Confrn Hold Endcall Park
Can I add the softkey by modifying the template? If so, how should the template be modified? Is there another line to add for "in conference" status?
We are using CME 3.2 on IOS 12(3)11T10
Added: I did try adding that softkey to the template, but it gave me the message that the input was not valid. It's not an option for softkeys connected:
Spohn_CME(config-ephone-template)#softkeys ?
alerting Softkey order for alerting (ring out) state
connected Softkey order for connected state
idle Softkey order for IDLE state
seized Softkey order for seized state
Spohn_CME(config-ephone-template)#softkeys connected ?
Acct Account Code
Confrn Conference
Endcall End call
Flash Hook Flash
Hold Hold
Park Call Park
Trnsfer Call Transfer
Thank you
Green
Re: Missing "RmLstC" softkey
AFAIK softkey "RmLstC" is only available in Call Manager but this not available on CME.
Hall of Fame Super Red
Hi Miriam,
Have a look at this new feature released with CME 4.0;
**Drop last party** or keep parties connected 12.4(9)T
12.4(4)XC
New options for the keep-conference command can be configured per ephone to specify whether the last party that joined a conference can be dropped from the conference and whether the remaining two parties should be allowed to continue their connection after the conference initiator has left the conference.
**drop-last ** The action of the Confrn soft key is changed; the conference initiator can press the Confrn soft key (IP phone) or hookflash (analog phone) to drop the last party.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00806a80c8.html#wp2291366
Hope this helps!
Rob
This Soft Key allows you to drop the last conferenced party from an Adhoc conference.
Meetme conferencing doesnt use this key.  Instead it used ConfList with the remove sub option.
612
