Mixing IBM and HP servers in a cluster
Are there any known problems mixing HP and IBM servers in CUCM 4.X, 6.X, and 7.X clusters?
1 REPLY
Re: Mixing IBM and HP servers in a cluster
Not really, as long as you do not mix different models ie 7845 with 7825 and configure failover that goes over the limit the server can handle
you should be OK using a mix of vendors.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
448
