Community Member
MLA CUCM 4.1(3) query
We are running CUCM 4.1(3). MLA is not enabled & value is set to " False". Is it possible to enable MLA & then disable it again, if it's required?
1 ACCEPTED SOLUTION
Community Member
Re: MLA CUCM 4.1(3) query
Yes, We can enable and disable the MLA options.
After enabling the MLA, if you disable it,the CCMAdministrator Account will not be used and all the restrictions will given to the users and user groups will be removed .i.e, basically all the MLA Configuration will not be in place. The windows Administrator Account will used for CCMAdmin Page Authentication.
And refer the below link for more detailed info:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803eda81.html
Kumar.V
Community Member
Kumar.V
Community Member
Kumar,
Thanks a lot. Actually I was doing a bit of research myself & found that it's possible from the back-end also. In SQL Enterprise Manager, we have to go to "MLAParameter" table in CCM 003XX database & change F to T & then restart IIS Admin service.
Abhijit. ( Bangalore)
118
