Mobile Conect Feature
I would like to implement mobile Connect feature within our network. Can someone answer my queries regarding the implementation plz...
1. My Gateways are currently being configured as MGCP. Do i need to change them to H.323?
2. Do i need to install any software client on the end uers mobile phones?
3. Except H.323 do i need to configure any other things in the vocie gateway?
If someone could share me the config for H323 for supporting Mobile Connect...
Rgds,
Partha
1 ACCEPTED SOLUTION
Re: Mobile Conect Feature
1. For remote destination you can use MGCP, if you want MVA then you do need to switch to H323
2. no, that's CUMA do not confuse products
3. If MVA the dial-peer with the app
Look Features and services guide for your CUCM version and the mobility chapter has all the config and explanation.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Hi Java,
Thanks for your reply..can you share me any sample config for h323 plz..
Already told you the F&S guide has all that
Bookmark this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/tsd_products_support_series_home.html
Whenever you need documentation or someone tells you to look into a document go to that link and you'll find the docs.
java
java
157
