12-12-2011 09:52 AM - edited 03-16-2019 08:30 AM
I have configured Mobile Connect on CUCM 8.0 and it is working ok.
However the Calling Number presented to internal phones is now the DN of the line associated with the Remote Desktop Profile. The customer uses four digit extensions so the called party sees for example 2569 rather than the number of the mobile phone that I am using to make the call.
I guess that this is by design but it breaks a UCCX script that reads the number of the calling party and stores it in an XML file where it is later used for dialout purposes.
My question is when a user is configured with Mobile Connect can I get the system to use the CLI received by the gateway (i.e. the number of the phone that placed the call) rather than the Diectory Number associated with the user.
12-12-2011 12:22 PM
Is there any place to use calling number transformation CSS to mask it as a full number rather 4digit?
12-12-2011 01:00 PM
Calling Party transformations are one of the workarounds that I am considering (along with building intelligence into the UCCX script).
Unfortunately there in no relationship between DN's and mobile numbers so a Transformation would be needed for every user. Setting this up initially would not be a problem but maintaining it might be so if I could get UCM to present the real calling number it would save alot of headaches.
