Mobile Connect when calling from External
I have an interesting problem with Mobile Connect on a Callmanager 6.1.2.
When Mobile Connect is programmed on a extension and a user from outside calls the phone, they hear a single ring and then silence until the call is answered or is sent to voicemail. If I remove the Mobile Connect Profile for the extension, the caller hears the normal cadence of rings. Other testing shows that this does not seem to affect calls from IP phone to IP phone.
Any ideas.
Re: Mobile Connect when calling from External
Any luck w/ a solution on this one? I am seeing the same issue.
J
Hall of Fame Super Silver
Are you using H323? If so you need to set progress indicators on the dial-peers.
Chris
GW is running H323 w/ a "progress_ind setup enable 3" on the voip dial-peers.
Thanks.
Did you find a solution to your problem ? I have the same issue.
Louis
Have a look at: http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml.
1. Configure the voice call send-alert Cisco IOS global configuration command in the terminating gateway/router.
This command enables the terminating gateway to send an alert message instead of a progress message after it receives a call setup.
HTH, please rate if so.
I work fine for me
thank you
155
