Mobile phone call get disconnect
In CUCM 7.1 setup, customer integrates third party IVR box with SIP trunk, communication between CUCM and IVR box working perfect including agent, supervisor and hunt group.
But when IVR try to transfer call to mobile phone, it goes as missed calls in mobile phone, landline call transfer from IVR is working perfect. Please let me the solution .
Everyone's tags (2)
Could you confirm, if the voice gateway used to call Mobile phones ( GSM/CDMA ) is different than the voice gateway used to call Landlines ?
Can you provide a call flow diagram when the call is transferred from IVR to Mobile phones ? I.e. which components the call traverse through while it reaches the mobile phone over PSTN ?
GP.
Voice Gateway [ 2921 configured as MGCP, CUCM 7.1 ], Mobile  Phone using GSM.
In third party IVR, when the customer selecting a particular option the call will be transfer to GSM number as missed call.
Bala,
My question is still unanswerred, therfore I wd still ask the same questions..
1. Could you confirm, if the voice gateway used to call Mobile phones ( GSM/CDMA ) is different router than the voice gateway router used to call Landlines ?
2. Can you provide a call flow diagram when the call is transferred from IVR to Mobile phones ? I.e. which components the call traverse through while it reaches the mobile phone over PSTN ? Following could be an example of call-flow diagram
e.g. IVR >> CUCM >> Gateway >> PRI/SIP Trunk >> Mobile user at PSTN
GP.
1) We are using one voice gateway, configured as MGCP  the same voice gateway is configured to call GSM and Landline.
2) When customer chooses some option in IVR, the call should to transfer GSM or landline.
Call-flow diagram, third party IVR -> SIP trunk -> CUCM 7.1 -> MGCP gateway - ISDN PRI - mobile user.
Note - I had created CTI route point in CUCM - 7771;  DN -  7771 call are forward to mobile number 922223333, when we call the CTI point [ 7771] form IP Phone the call is hitting the GSM normally, when the DN - 7771, call is initiate  from IVR, the mobile get call as missed call.  Land line call transfers are working perfect.
1. Does the call ( IVR transfer to Mobile ) get disconnected as soon as Mobile user answers the call ?
2. or does the call disconnect after ringing on Mobile for say 2 rings & thus leaves a missed call ?
If it's the case 1, then we should check Codec negotiation config for the call leg of IVR to Mobile user. Case 1 is perfect symptom of Codec issue, i.e. signalling goes well but call drops as codec is not negotiated properly.
Pls lemme know how it goes.
GP.
Our issuse is - call disconnect after ringing on Mobile for say one rings & thus leaves a missed call in mobile phone ?.
Please let me know workaround for this issuse.
Try enabling MTP for mobile calls. i.e. Check MTP required field.
GP.
We had checked MTP field, but same result, call get disconnected after one ring. But for Landline there is no problem, could you please light me more info related to troubleshoot.
I am receiving a similar issue. To answer the same questions:
CUCM Version 8
-Gateway being used for landlines is the same gateway being used for mobile calls.
2. Can you provide a call flow diagram when the call is transferred from?
PSTN -> Incomming call -> Gateway -> DN -> Call Forward All CSS -> Gateway -> PSTN
Call processing completes, but the call drops after a single ring. See below for a debug isdn q931 for call process. (Removed last 4 digits with X's)
*Dec 26 18:51:24.899: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0013
                Bearer Capability i = 0x8090A2
                                Standard = CCITT
                                Transfer Capability = Speech
                                Transfer Mode = Circuit
                                Transfer Rate = 64 kbit/s
                Channel ID i = 0xA98397
                                Exclusive, Channel 23
                Progress Ind i = 0x8283 - Origination address is non-ISDN
                Calling Party Number i = 0x2183, '832444XXXX'
                                Plan:ISDN, Type:National
                Called Party Number i = 0x80, '1936668XXXX'
                                Plan:Unknown, Type:Unknown
*Dec 26 18:51:24.931: ISDN Se0/0/1:23 Q931: RX <- STATUS pd = 8  callref = 0x0D25
                Cause i = 0x80E018 - Mandatory information element missing
                Call State i = 0x06
*Dec 26 18:51:24.991: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8013
*Dec 26 18:51:27.831: ISDN Se0/0/1:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8013
                Progress Ind i = 0x8288 - In-band info or appropriate now available
*Dec 26 18:51:27.835: ISDN Se0/0/1:23 Q931: TX -> PROGRESS pd = 8  callref = 0x8D25
*Dec 26 18:51:27.871: ISDN Se0/0/1:23 Q931: RX <- STATUS pd = 8  callref = 0x0D25
                Cause i = 0x80E503 - Message not compatible with call state
                Call State i = 0x06
*Dec 26 18:51:28.791: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0D25
                Cause i = 0x8092 - No user responding
*Dec 26 18:51:28.803: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0013
*Dec 26 18:51:28.871: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x8013
*Dec 26 18:51:28.903: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0013
Let me know if you need any more information.
Yes we are facing the same issuse, please advice the solution.
Re: Mobile phone call get disconnect
You should negotiate signalling details with your telco. Ask them what IEs they awaiting.
Typicaly problems where some destination not working occurs when you send incorrect type/plan.
Now we are not sending dail plan type for called or calling number, we will try this also.
But when we called GSM number from Cisco - IP Phone the call is completed normally, when a GSM call is initiate from third party IVR box to cisco call manager via SIP trunk, the call is disconnected after one ring, Land line call transfer it works normal.
Call flow :
incoming call from PSTN->Cisco MGCP gateway E1 ->CUCM 7.1->SIP Trunk-> Third party IVR box -> for some option IVR need to transfer call to GSM  via-> SIP trunk -> CUCM 7.1 -> Voice gateway - Mobile users. Mobile user call drops after one ring.
For  IVR - land line call transfer there is no issuse, please light me more detail to troubleshoot this issuse further.
First compare debug isdn q931 for successful and failed call to one number. After you find what changes you can tune the SIP trunk.
Regards, Maxim
For failed call we are getting the error as  "cause code - 0x82E6" ,
In ISDN we will mark numbering plan type and we will see the ISDN debug output, but I dont think because of plan type the call will drop by Telco.
for GSM,  route pattern able to call from Cisco IP Phone normally, IVR also hitting the same GSM route pattern and goes as missed call.
Please provide full debug isdn q931 from setup to release complete for both successful and unsuccessful call.
Regards, Maxim
Below debug & Sh run is pasted:
In SIP trunk MTP required is checked,
Missed call debug as below:
DN - 7605 is from IVR
DN- 7771 is CTI route point
VoiceGateway-ABO#
*Jan  1 06:54:34.250: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0E1D
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
        Channel ID i = 0xA9839D
                Exclusive, Channel 29
        Progress Ind i = 0x8083 - Origination address is non-ISDN
        Display i = '7605'
        Calling Party Number i = 0x0083, '7605'
        Called Party Number i = 0x80, '9931x9xx24'
        Redirecting Number i = 0x00008F, 7'771'
*Jan  1 06:54:34.278: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8  callref = 0x8E1
D
        Cause i = 0x82E398289874 - Information element not implemented
        Call State i = 0x01
*Jan  1 06:54:34.290: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x
8E1D
*Jan  1 06:54:38.830: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8
E1D
        Progress Ind i = 0x8488 - In-band info or appropriate now available
*Jan  1 06:54:38.890: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0
x0E1D
        Cause i = 0x8290 - Normal call clearing
*Jan  1 06:54:38.942: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8E
1D
*Jan  1 06:54:38.966: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x0E1D
*Jan  1 06:54:42.494: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0
x0E1B
*Jan  1 06:54:42.558: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8E
1B
*Jan  1 06:54:42.578: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x0E1B
Normal call clearing:
Jan  1 06:49:29.426: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0E14
        Sending Complete
                Standard = CCITT
        Channel ID i = 0xA9839A
                Exclusive, Channel 26
        Display i = 'Waseem Al Busaidi'
        Calling Party Number i = 0x0081, '7129'
        Called Party Number i = 0x80, '99xx4xx924'
*Jan  1 06:49:29.454: ISDN Se0/0/0:15 Q931: RX <- STATUS pd = 8  callref = 0x8E1
        Call State i = 0x01
*Jan  1 06:49:29.470: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x
Sh run for MGCP gateway:
version 12.4
hostname VoiceGateway-ABO
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 5 $1$67Aj$2ndOtJXApHn5hxHzx6IDx/
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
dot11 syslog
ip cef
isdn switch-type primary-4ess
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
  allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol pass-through g711alaw
h323
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
username ahli password 0 cisco
archive
log config
  hidekeys
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
shutdown
ip address 10.69.x.x 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.69.25.7 255.255.255.0
service-module ip default-gateway 10.69.25.1
no keepalive
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.69.25.1
ip route 10.69.x5.y 255.255.255.255 Integrated-Service-Engine1/0
no ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
cptone OM
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
ccm-manager redundant-host 10.69.a.b
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config
mgcp
mgcp
mgcp call-agent 10.69.25.5 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode nte-ca
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability fm-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.69.x.6 identifier 1 priority 1 version 5.0.1
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 3 register siptrunk
associate profile 2 register CCM-CONF
associate profile 1 register CCM-SUB
dspfarm profile 1 transcode
codec g711ulaw
codec g729ar8
maximum sessions 7
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g729ar8
codec g729r8
codec g711alaw
codec g729abr8
codec g729br8
maximum sessions 2
dspfarm profile 3 mtp
description software MTP
codec g711ulaw
codec pass-through
maximum sessions software 10
dial-peer voice 100 voip
destination-pattern 7...$
session protocol sipv2
session target ipv4:10.69.y.z
incoming called-number .T
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 999 pots
service mgcpapp
direct-inward-dial
port 0/1/0
dial-peer voice 998 pots
service mgcpapp
direct-inward-dial
port 0/1/1
dial-peer voice 997 pots
service mgcpapp
direct-inward-dial
port 0/1/2
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login local
scheduler allocate 20000 1000
Normal Call Clearing:
Jan  3 03:13:35.169: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x1835
                Standard = CCITT
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x2180, '281362XXXX'
        Called Party Number i = 0x80, '8649'
Jan  3 03:13:35.173: ISDN Se0/0/1:23 Q931: TX -> SETUP_ACK pd = 8  callref = 0x9835
Jan  3 03:13:35.197: ISDN Se0/0/1:23 Q931: RX <- STATUS pd = 8  callref = 0x1835
        Cause i = 0x80E10D - Message type not implemented
        Call State i = 0x06
Jan  3 03:13:39.089: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x1835
                Standard = CCITT
Jan  3 03:13:39.213: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x9835
Jan  3 03:13:39.213: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0006
                Standard = CCITT
        Calling Party Number i = 0x2183, '281362XXXX'
        Called Party Number i = 0x80, '832444XXXX'
Jan  3 03:13:39.237: ISDN Se0/0/1:23 Q931: RX <- STATUS pd = 8  callref = 0x1835
        Call State i = 0x06
Jan  3 03:13:39.285: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8006
Jan  3 03:13:41.165: ISDN Se0/0/1:23 Q931: RX <- ALERTING pd = 8  callref = 0x8006
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Jan  3 03:13:41.169: ISDN Se0/0/1:23 Q931: TX -> ALERTING pd = 8  callref = 0x9835
Jan  3 03:13:49.165: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8  callref = 0x8006
Jan  3 03:13:49.169: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8  callref = 0x9835
Jan  3 03:13:49.169: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0006
Jan  3 03:13:49.205: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x1835
Jan  3 03:13:52.021: ISDN Se0/0/1:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x8006
        Cause i = 0x8090 - Normal call clearing
Jan  3 03:13:52.029: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x9835
Jan  3 03:13:52.053: ISDN Se0/0/1:23 Q931: TX -> RELEASE pd = 8  callref = 0x0006
Jan  3 03:13:52.085: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8006
Jan  3 03:13:52.261: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x1835
Jan  3 03:13:52.285: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x9835
Failed Call (Fast busy after first ring):
Jan  3 03:15:15.778: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x1836
                Standard = CCITT
Jan  3 03:15:15.782: ISDN Se0/0/1:23 Q931: TX -> SETUP_ACK pd = 8  callref = 0x9836
NDFHOU-C2851#
Jan  3 03:15:15.814: ISDN Se0/0/1:23 Q931: RX <- STATUS pd = 8  callref = 0x1836
        Call State i = 0x06
Jan  3 03:15:19.698: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x1836
                Standard = CCITT
Jan  3 03:15:19.834: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x9836
Jan  3 03:15:19.834: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0007
                Standard = CCITT
Jan  3 03:15:19.854: ISDN Se0/0/1:23 Q931: RX <- STATUS pd = 8  callref = 0x1836
        Call State i = 0x06
Jan  3 03:15:19.910: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8007
Jan  3 03:15:22.974: ISDN Se0/0/1:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8007
Jan  3 03:15:22.974: ISDN Se0/0/1:23 Q931: TX -> PROGRESS pd = 8  callref = 0x9836
Jan  3 03:15:22.990: ISDN Se0/0/1:23 Q931: RX <- STATUS pd = 8  callref = 0x1836
        Call State i = 0x06
Jan  3 03:15:23.694: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x1836
Jan  3 03:15:23.702: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0007
Jan  3 03:15:23.770: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x8007
Jan  3 03:15:23.798: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0007
Let me know if you need more information.
When we transfer call from IVR to CTI route point and forward the Mobile call to PSTN,  ISDN debug says normal call clearing, but the mobile call get disconnect in one ring.
Can I know the workaround for this above issuse ?
Green
Summing up what has been shown so far :-
Ip phone calls 7771 (CTI R-POINT) Xfers to Mobile OK
The MGCP is OK
Gateway is OK
CUCM (MGCP) is OK
That only leaves the issue with the SIP trunk
between CUCM  and the IVR.
When your call fails it when you receive the ALERTING from the SP
that the CUCM via MGCP is sending a DISCONNECT to the SP
I think you need to look at CUCM traces over the SIP trunk for the failed call
Alex
Regards, Alex. Please rate useful posts.
2087
СоздатьДля создания публикации, пожалуйста в систему
