Mobile Voice Access License/Limitation
I have some concern regarding MVA feature on the callManager CUCM, is there a license for this feature and what are the max number of users that can use this feature at the same time?
Ali
1 REPLY
Hall of Fame Super Silver
There is no explicit license for it, but in order for users to use it they must be configured with Mobility (under user page), it uses 1 DLU for each user.  As far as number of concurrent users at a time, this would be driven by the gateway platform you are using as you are using it for the IVR treatment, not sure if this is documented anywhere, perphas check out SRND.
Chris
312
