10-10-2013 10:03 AM - edited 03-16-2019 07:50 PM
I have setup MVA correctly on one site, after a few months, the call just comes into the voice gateway and then it drops, I have already setup the following:
1- Media Resources --> Mobile voice access number
2- Service parameters --> Mobile voice access number and mobile voice access is enabled
3- The partition that the number has is the correct one
4- On the voice gateway I have the following config:
dial-peer voice XXXX voip
destination-pattern 2938
session target ipv4:CUCM pub IP
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice XXXX pots
service ccm
incoming called-number 2938
no digit-strip
direct-inward-dial
service CCM http://<CUCM pub IP>:8080/ccmivr/pages/IVRMainpage.vxml
I have opened a TAC case but they are not sure where the problem is and the h323 config is fine because the rest of the calls are working correctly.
10-10-2013 10:28 AM
1- Did you check the registeration for your application , by do: show call application voice ccm.
2- When you do a call did you hear the welcome message?. when the call drop?.Make sure that your mobile voice access is enbaled on service parameters
3- for the voip dial-peer if your internale dial-plans starts with 2XXX , so you do not need this specified voip dial-peer for MVA?.Because for sure you have already have other VOIP dial-peer for your internal ext 2XXX.
Thank you
please rate all useful information
10-10-2013 10:39 AM
Hi Islam,
See the answer to your questions bellow:
1- Did you check the registeration for your application , by do: show voice call application ccm.
Script Name : CCM
URL : http://
Type : Service
State: Registered
Life : Configured
Exec Instances: 0
Script Code Begin:
VXML Application CCM
URL=http://10.1.6.10:8080/ccmivr/pages/IVRMainpage.vxml
Security Level: not trusted
47 incoming calls
0 calls handed off to it
0 call transfers initiated
0 pages loaded, 75 successful
47 prompt play attempts, 0 successful
0 recorded messages
The VXML Script is:
I don`t hear the welcome message the call stays active and silent for about 2 seconds and then it just drops
3- for the voip dial-peer if your internale dial-plans starts with 2XXX , so you do not need this specified voip dial-peer for MVA?. correct I just setup this dial peer to make sure I have the specific number on a dial peer
10-10-2013 10:47 AM
1- Please make sure that under the service parameters mobile voice access is enable.
2- Please do debug isdn q931.
Thank you
10-10-2013 10:52 AM
Please also type the below command
interface
h323-gateway voip interface
h323-gateway voip bind srcaddr xxx.xxx.xxx.xxx (Interface's ip address).
voice service voip
* please also check if your make complete match & partial match try to change it. If you using complete ,try to use partial and if you use partial try to use complete
Thank you
10-10-2013 12:46 PM
All this config was already on the router except for the complete match, I changed it to partial match but I still have the same problem. Here`s the debug isdn q931:
082025: Oct 10 19:45:06.309: ISDN Se0/1/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 22042153
082026: Oct 10 19:45:06.309: ISDN Se0/1/1:15 Q931: Sending SETUP callref = 0x5EF0 callID = 0xDE71 switch = primary-net5 interface = User
082027: Oct 10 19:45:06.309: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8 callref = 0x5EF0
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839E
Exclusive, Channel 30
Progress Ind i = 0x8183 - Origination address is non-ISDN
LACRSJRO06#
Calling Party Number i = 0x0081, '22042153'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '22042938'
082028: Oct 10 19:45:06.533: ISDN Se0/1/1:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0xDEF0
082029: Oct 10 19:45:06.665: ISDN Se0/1/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xDEF0
082030: Oct 10 19:45:06.869: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0300
Sending Complete
Standard = CCITT
Channel ID i = 0xA98389
Exclusive, Channel 9
Progress Ind i = 0x8583 - Origination address is non-ISDN
Calling Party Number i = 0x2081, '22042153'
Plan:Unknown, Type:National
Called Party Number i = 0x81, '2938'
Plan:ISDN, Type:Unknown
082031: Oct 10 19:45:06.869: ISDN Se0/1/0:15 Q931: Received SETUP callref = 0x8300 callID = 0x4756 switch = primary-net5 interface = User
082032: Oct 10 19:45:06.881: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8300
082033: Oct 10 19:45:06.881: ISDN Se0/1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8300
082034: Oct 10 19:45:07.241: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8300
Cause i = 0x8090 - Normal call clearing
082035: Oct 10 19:45:07.313: ISDN Se0/1/1:15 Q931: RX <- CONNECT pd = 8 callref = 0xDEF0
Date/Time i = 0x0D0A0A0D2D00
Date (dd-mm-yr) = 13-10-10
Time (hr:mnt:sec) = 13:45:00
082036: Oct 10 19:45:07.313: %ISDN-6-CONNECT: Interface Serial0/1/1:29 is now connected to 3212075 N/A
LACRSJRO06#
082037: Oct 10 19:45:07.313: ISDN Se0/1/1:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x5EF0
082038: Oct 10 19:45:07.749: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0300
082039: Oct 10 19:45:07.749: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8300
082040: Oct 10 19:45:07.853: ISDN Se0/1/1:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xDEF0
Progress Ind i = 0x8288 - In-band info or appropriate now available
082041: Oct 10 19:45:07.853: ISDN Se0/1/1:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0xDE71
LACRSJRO06#
082042: Oct 10 19:45:08.073: ISDN Se0/1/1:15 Q931: TX -> RELEASE pd = 8 callref = 0x5EF0
082043: Oct 10 19:45:08.237: ISDN Se0/1/1:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xDEF0
10-10-2013 03:37 PM
Can you please share with me the "show call application voice summary" command ?. Maybe there are a problem on the VXML when your router is trying to open the VXML application.
Thank you
10-10-2013 10:09 PM
If it's possible then please share "debug voice ccapi inout" & "debug voice dialpeer" separately.
Also share your running config of VG.
Nishant Savalia
