Community Member
Mobile Voice Access not working
HI I have CUCM 7.0 and 3845 as H.323 gateway.
I have setup the Mobile voice access(MVA) and when i dial MVA number CCM plays the IVR...during IVR it prompts for authentication..
Problem1: I am dialing the MVA number from a phone configured as Remote destination for user.But still it is asking for remote destination number and pin..ideally it should be asking for only pin and not for remote DN dialing from a phone configured for remote destination..
Problem2: Document says after authentication you should press1 and dial the remote number you want to dail. But as soon as i press1 the IVR says invalid input.
Any suggestion will be helpful
Thanks& rgds,
Alok
Community Member
Re: Mobile Voice Access not working
Problem 1 : Have you checked the phone you calling from doesnt have the cli restricted ? Check the cli being passed to CCM is exactly the same as whats configured as your remote destination.
Problem 2: Check the RDP profile is configured correctly. Also which country are you in and can you post a sh run of your voip dialpeer.
Community Member
HI Sebastian,
Thanks for your reply.
I have checked the things you told.
Problem 1: i have 0 dialing so remote destination i have configured as "0xxxxxxxxxx" while the incoming mobile number is "xxxxxxxxxx"..SO the 0 is not prefixed to the incoming number.
Problem2: RDP profile is correct. I am in India.Below is the dial-peer configuration...
dial-peer voice 6800 pots
service ccm
incoming called-number 6800
no digit-strip
direct-inward-dial
dial-peer voice 6801 voip
destination-pattern 6800
session target ipv4:10.118.42.10
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Thanks & Regds,
Alok
Community Member
Hi Alok,
We had better add user's extension as one of associated remote destination, if user dial in with one of the remote destintation DN, the system will ask user key PIN password instead of asking user input user ID and PIN password.
Michael.
296
