Mobile Voice Access with voip call?
Can I use Mobile Voice Access for the below.
Calls from spain come in over the WAN. Then, we want to allow callers to dial-out to the PSTN here in the states. I got this working with normal inbound PRI calls.
I tried to setup with first leg being voip (only difference was inbound dial peer was voip instead of pots). But call just drops. debug voip dialpeer shows that it get routed to correct dial-peer).
thanks
1 ACCEPTED SOLUTION
Green
Re: Mobile Voice Access with voip call?
Try G.711 for that voip dial-peer it should work.
So the other side should announce G711 instead of 729 otherwise i dont it will work
Since application in the voip wont be able to play succesfully the prompts or to connect
This may be a codec issue. Have you verified the codecs in use through all of your call legs?
Can you give me the debug command to verify?
Green
206
