Mobile voice Access working but can't make outside calls
aysar3000
Dears
i configure mobile voice access and i can hear the IVR when i call from a PSTN Line and i input my Remote destination number then it ask me for my PIN and i put it then it ask to press one for a call and after that i dialed the number but it give busy tone
here is my configuration
my MVA number is 7999
my IOS COnfiguration
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
 codec preference 4 g729br8
voice translation-rule 3
 rule 1 /^9\(\)/ /\1/
voice translation-rule 4
 rule 4 /^22217/ /7/
 rule 5 /^2217/ /7/
 rule 6 /^022217/ /7/
 rule 7 /^0122217/ /7/
voice translation-rule 5
 rule 1 /^5/ /905/
 rule 2 /^1/ /901/
 rule 3 /^2/ /902/
 rule 4 /^3/ /903/
 rule 5 /^4/ /904/
 rule 6 /^6/ /906/
 rule 7 /^7/ /907/
 rule 8 /^8/ /908/
 rule 10 /^00/ /900/
 rule 11 /'+'/ /900/
voice translation-rule 9
 rule 1 /^5/ /05/
voice translation-profile MVA
 translate calling 9
voice translation-profile OUT
 translate called 3
voice translation-profile REDIAL
 translate calling 5
voice translation-profile SIP-NEW
 translate called 4
dial-peer voice 802 voip
 description ** SIP TO STC **
 translation-profile outgoing OUT
 destination-pattern 9T
 session protocol sipv2
 session target ipv4:10.208.9.69:5060
 session transport udp
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 voice-class sip profiles 1
 dtmf-relay sip-notify rtp-nte sip-kpml
 fax rate disable
 no vad
 voice-class codec 1
 fax rate disable
 no vad
dial-peer voice 811 voip
 description ** SIP INCOMING FROM STC **
 translation-profile incoming SIP-NEW
 translation-profile outgoing REDIAL
 destination-pattern 7...
 session target ipv4:192.168.200.53
 incoming called-number 022217...$
 voice-class codec 1
 fax rate disable
 no vad
dial-peer voice 812 voip
 incoming called-number 22217...$
 codec g711alaw
dial-peer voice 7999 voip
Description "MVA"
 service mva
 incoming called-number 2217999
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 7991 voip
 destination-pattern 7999
 voice-class codec 1
 dtmf-relay rtp-nte
 fax rate disable
 no vad
in the service parameter
 False
 Complete Match
Thanks in Advanced
Hi.
Did you check that CSS of associated DN on Destination Profile an redirect CSS allows you to call out?
Let us know.
Carlo
Please rate all helpful posts "The more you help the more you learn"
32 Replies 32
aysar3000
Sorry for the mistake in the picture
Enable Mobile Voice Access  Required Field True
Mobile Voice Access Number 7999
Matching Caller ID with Remote Destination  Required Field Partial Match
Number of Digits for Caller ID Partial Match  Required Field 7
Can you do another test call and send us a "debug ccsip messages"
Please include the calling and the called number
Please rate all useful posts
Dears
the RD Number is 90565285270
i called the MVA 92217999
and then i dialed the number 90540533364
Thanks in Advanced
The logs showing 404 not found..
Can you send your config please..
Received:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 192.168.200.86:5060;branch=z9hG4bK256124F2
From: <sip:90565285270@192.168.200.86>;tag=6D99910-1AD7
To: <sip:7999@192.168.200.53>;tag=173206~244641b0-36ac-434c-91c1-823f25a68b28-24866165
Date: Thu, 02 Oct 2014 15:15:35 GMT
Call-ID: CAE4A53F-497D11E4-AF9A9583-B978D042@192.168.200.86
CSeq: 101 INVITE
Allow-Events: presence
Reason: Q.850;cause=1
Content-Length: 0
Dears
i attached the SIP GW Configuration
Hi.
Are you able to call internal extensions such as Voicemail Pilot or collegues extension?
Let us know
Carlo
if you mean after i dialed the MVA then the answer is no
but if you mean from my local extensuoin o normal extension then yes
Hi.
This usually happens when:
-MVA directory number is not correctly configured on CUCM (Both service parameter and media resource)
-Dial Peer to MVA is not or not correctly configured
-Configured Incoming and redirect CSS on SIP / H323 trunk is unable to reach MVA Extension partition
Check it and let us know
Carlo
Dears
im actually reaching the MVA Number and i hear the IVR and everything going right till the moment it ask me to dial a number after i dial it get busy tone and my phisical extension keep flashing
if any of the GW configuration is wrong it wouldnt go to the MVA
can you tell me the steps to the right configuration so i can go through it
Make sure you have "Inbound Calling Search Space for Remote Destination" CallManager Service Parameter set to "Remote Destination Profile + Line Calling Search Space".
By default, it will use the trunk's CSS to try to reach the external number you try to dial which might not work in your environment.
Hi.
Brian is correct (+5) but to tell te truth... I have the default value for that parameter but CUCM keeps using RDP/Line CSS.
What I suggest is to check those CSS.
Can you also please send the output of a debug ccsip message while calling an internal extesion from MVA?
Carlo
Dears
i change it to Remote Destination Profile + Line Calling Search Space"
but still nothing work
Hi.
Which version of CUCM are you running?
Let us know
Carlo
it's
System version: 8.6.2.20000-2
