08-28-2007 07:03 AM - edited 03-14-2019 11:15 PM
Does anyone have a user / install guide for mobility manager and connect for callmanager 6
08-28-2007 10:44 PM
08-29-2007 03:01 AM
I need steps for mobility connect feature on CM6, I have followed the standard guide but keep getting the error
Not a valid mobile phone user
When I select the mobility softkey?????
08-30-2007 03:09 AM
you probably forget to configure the "Owner User ID" field in the device phone configuration. Try to add a user in that field and the issue should be solved.
Dom.
09-29-2010 02:56 PM
That was exactly my issue also
09-30-2010 07:32 AM
The problem is due to known defect :
CSCsg64857 You are not a valid Mobile Phone user Displayed with Mobility softkey
- Sriram
