Mobility on CUCM
Hii,
I activate the Remote destination and Remote Destination Profile for my extension but I want after 4/5 ring on the desk phone the call to be transferred to My Mobile, is working after I checked the
The problem is that it rings only 2 times on my desk and it is transferred to my Mobile, from where I can change the nr of rings on the desk Phone?
Th for help
1 ACCEPTED SOLUTION
Re: Mobility on CUCM
Hi Gabriel.
Check your delay before ring timer on mobile identity configuration page
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Gabriel.
Carlo
Mobility on CUCM
Th Carlo
72
