mobility profiles- logout?
HII all,
I Have set up mobility profiles for metting rooms, and are workign fine the problem is I do not have an option to logout of the profile once signed in I am using Cisco IP Phone 7940 series.
I must be missing a setting somewhere can somebody point me in the right direction? I am using call manager version 7
Thanks in advance.
Martin
1 ACCEPTED SOLUTION
Silver
Re: mobility profiles- logout?
go to the User Device Profile page and assign the EM phone service to the user- top right of page - drop down menu
the fact you can log in  means the end user page configuration is correct so it is just the UDP missing the EM phone service
Silver
It sounds like you need to assign a EM service to the UDP profile as well so they can use the service to log out
Thank you for your reply and sorry to be thick, but I havetn been using Call manager long(couple of days) could you break that down a bit for me.
Silver
Thank you very much, you have just made my day alot easier.
Thanks.
176
