Mobility remote destination number of rings
Is there any way to change the amount of rings it takes for a cell phone to begin to ring when setting up Cisco Mobility? Currently it takes about 2 rings before our cell phones rings with mobility enabled. I was wondering if there was any way to change this to about 1 ring.
I'm on Call Manager 8
Have you already played with these settings??
Answer Too Soon Timer
Delay Before Ringing Timer
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
VIP Super Bronze
In addition to Java's response: Be aware that many cell phones have a delay before they start ringing which is beyond the control of CUCM. You can pin this down by watching your gateway/trunk to mark the time between when the SETUP/INVITE is sent and when the phone actually rings. Even if you set the Delay Before Ringing Timer to zero (0), you may still experience a ring or two worth of delay. Your only way to combat this is to raise the Call Forward No Answer timer on the DN and the Answer Too Late Timer.
Please remember to rate helpful responses and identify helpful or
yes. I haven't noticed a difference. It's still taking at least 3 rings before the cell phones ring. I wasn't sure if this was standard or not or if this can be controlled.
Re: Mobility remote destination number of rings
Take a good look a your Route Patterns and try to specify them, if there is an exact match it should ring after a single ring om the deskphone.
700
