modem connected to VG224 in SCCP
I've a callmanager connected to 2 VG224 in SCCP. I've several analog phones and faxes and all works fine ( in pass-through ).
The callmanager is connected to a VG2851 and this one is connected to a primary E1.
The trouble is that I've connected a modem and there is no way to make it works. I hear "continuosly" the tipical modem call beeping but the calls does not connect to the other endpoint. It seems like it fails the handshake.
Any help/experience ?
Many Regards
Luigi
Green
Re: modem connected to VG224 in SCCP
At this time, fax passthrough on SCCP controlled VG224 FXS port is not supported.
http://www.cisco.com/en/US/partner/products/ps6441/products_feature_guide091
86a0080483a76.html#wp1218890
Restrictions for SCCP Analog Ports
?Modem and fax-relay are not supported on FXS ports with SCCP enabled; only modem and fax
pass-through are supported. Configure FXS ports with either fax or modems attached in
H.323 or SIP mode.
This is a bit confusing (badly worded) It should read,
Modem and t38 fax-relay are not supported on FXS ports with SCCP enabled.
Only modem and fax pass-through are supported, configure FXS ports with
either fax or modems attached in H.323 or SIP mode. Please change to one of these protocols and verify if that fails.
So, you can still configure VG224 with CCM to use SCCP. In CCM, do not configure/provision
the ports you have fax machines on and use H323 for those.
thanks for the reply.
All fax are working fine; I'm having troubles only to modem. I've to setup another H.323 gtw ?
Luigi
Hi, I hope you VG224 starts working fine :--)
I am about to install 14 VG224 With CCM ...
I am planing to use MGCP and looking for your advice on that either I use H323 or MGCP
Also any help regarding how to configure VG224 and see it in CCM will be higly appreciated ....waiting to hear from you
Kind Regards,
Fawad
sorry but i'm configured in SCCP because by this way the analog telephone are configurable like IP-phone. Some people told me that for modem could be better H.323, but modems are not so important, in my deployment.
regards
Luigi
Thanks for your reply
Hi !
This problem can solved by doing the following on VG2851 & VG224 :
- In VG224: check configuration again and add the following commands:
voice service voip
modem passthrough nse payload-type 110 codec g711alaw redundancy maximum-sessions 1
- In VG2851: check configuration again and add the following commands:
voice service voip
modem passthrough nse codec g711alaw redundancy
dial-peer voice 4 voip
description ***** Destination *****
destination-pattern 4...
session target ipv4:
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Hope these commands help you solving the problem.
Tks
PS: SCCP and MGCP are tested. Now everything are working properly.
hi, i also find the solution for this issue,
CCM(5.x)--MGCP--ISR
CCM--SCCP--VG224(12.4.15)
Analog and fax works fine, but modem is always failed.
according to your confiugraion list above, I want to know whether the 'dail-peer voice 4 voip' can work, since the protocol between ccm and isr is mgcp, so i don't think this dial-peer can work.pls help
Hi Luigi.
I'm dealing with a similar scenario here; VG224 with SCCP and voice & fax (passthrough) calls are fine. The modem passthrough calls inbound (from PSTN) are still fine, but all the modem call out are failing.
All originating&terminating gateways are both configured for modem passthrough nse payload-type 110 codec g711ulaw redundancy.
Any ideas? Could you find a resolutions to your case?
Cristian
Did the configuration listed above work for this problem? We are looking at this as well.
Mike
1413
