Modem Dropping Connection After 30 mins
c.walsh
Level 3
Level 3
Hi we have a customer using CM 6.0 with modems running over ATA's with an MGCP G/W.
They use the modems for remote access, however they drop their connection after 30 mins of being connected. This is dependant on whatever model of modem is used.
pcameron
Could be related to this -
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_field_notice09186a0080094af7.shtml
Even though it talks about fax passthrough, this works the same as modem passthrough.
Also,if you use a T1 or E1 digital interface on your MGCP gateway, ensure you have 'network-clock-select 1 e1/t1 ...' configured to ensure correct synchronisation of the DSP's and to prevent clock slips as these will break modem/fax calls.
