Modem Dropping Connection After 30 mins
Hi we have a customer using CM 6.0 with modems running over ATA's with an MGCP G/W.
They use the modems for remote access, however they drop their connection after 30 mins of being connected. This is dependant on whatever model of modem is used.
1 REPLY
Re: Modem Dropping Connection After 30 mins
Could be related to this -
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_field_notice09186a0080094af7.shtml
Even though it talks about fax passthrough, this works the same as modem passthrough.
Also,if you use a T1 or E1 digital interface on your MGCP gateway, ensure you have 'network-clock-select 1 e1/t1 ...' configured to ensure correct synchronisation of the DSP's and to prevent clock slips as these will break modem/fax calls.
90
