Community Member
Modem fails with VG204
I have a call manager v7.1 in the UK  and I have configured a VG204 to handle FAX and modem calls.  I have configured it with MGCP.  The FAX calls go through, however the modem calls connect to the other side, go through a prolonged handshake, then disconnect.  Am I missing something in the config?  Here it is:
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$tHRU$jvHqBxlJlQefJWVGUnslw.
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice-card 0
username Administrator privilege 15 password 0 ****
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.133.10.40 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.133.10.1
ip http server
control-plane
voice-port 0/0
cptone GB
voice-port 0/1
cptone GB
voice-port 0/2
cptone GB
voice-port 0/3
cptone GB
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.133.10.10
ccm-manager config
mgcp
mgcp call-agent 10.133.10.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
mgcp package-capability sst-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 99920 pots
service mgcpapp
port 0/0
dial-peer voice 99921 pots
service mgcpapp
port 0/1
dial-peer voice 99922 pots
service mgcpapp
port 0/2
dial-peer voice 99923 pots
service mgcpapp
port 0/3
dial-peer voice 99900 pots
service mgcpapp
port 0/0
line con 0
no modem enable
line aux 0
line vty 0 4
password ****
login local
exception data-corruption buffer truncate
end
Thanks for your help.
Community Member
Re: Modem fails with VG204
Below is a sinp-it from my config...
voice service voip
modem passthrough nse codec g711ulaw
Also be sure you have the same MGCP and voip sevice voip configured in your final gateway to the PSTN.   In Call Manager be sure that modem passthrough is enabled on the VG and your PSTN gateway.
Good luck!
Community Member
Ed ,
Whats the call flow here ?
modem>>MGCP>>>CUCM---SIP/MGCP/H323---PSTN/ITSP ?
NSE based modem passthrough takes the fax traffic inband over the network
We need to make sure that this is a normal voice call at g711 no VAD .
And we might need to get rid of this command which might send the wrong PT to the terminating gateway (PSTN) in case the terminating gateway is not configured for it .
no mgcp modem passthrough voip mode nse
no mgcp modem passthrough voip  codec g711alaw
also check the output of show controller e1  .
Also please paste show controller e1 and show run output from your PSTN gateway
Community Member
Outbound it goes from the modem to the VG204 which is registered with CUCM and is then sent to a 2801 with a VWIC2-1MFT-E1 using MGCP and delivered to the PSTN.
Community Member
In this case you have to try anb disable the modem passthrough on both the originationg gateway ( vg202 ) and terminating gateway (PSTN)
Also make sure that you have both these parameters disabled on the controller page of the CUCM
If this also doesnt work
Then
following debugs will help
debug voip ccapi inout
debug voip vtsp all
debug mgcp packet
debug isdn q931( from the pstn gateway)
taken  from both the gateways . Please respond back with calling called party numbers
Community Member
also debug voip rtp session named-events
Community Member
Here are thet debugs from a cal.  The CUCM has modem passthrough, Cisco FAX Relay and T.38 Relay set to disable.
Community Member
Here is the requested output.  On CUCM should the VG204 gateway be set to:
Modem passthrough - Enable
Cisco Fax Relay - Disable
Cisco T38 Relay - Disable
The called number is 08456017009
2389
