Modem relay issue between two H.323 Voice Gateways
Hi all,
I have the following situation:
There are 2 locations, A and B, each having a Cisco 2851 Voice Gateway, interconnected via a MPLS VPN Provider. Each Voice Gateway is an H.323 Gateway, and has POTS and VoIP dial peers.
For modem relay configuration, I have the following:
voice service voip
  h323
    call start slow
  modem relay nse codec g711alaw gw-controlled
I have the following issue when dialing for a modem call:
For a call from A to B results a modem relay connection, but for a call from B to A the resulted connection is not modem relay, and it drops the call.
The configurations from both A and B Voice Gateways are approximately identical. Both Voice Gateways are connected to a Cisco Unified Call Manager.
Each A and B Voice Gateway has a EVM-HD-8FXS/DID module and an PVDM2-48.
Any help on this issue is welcome.
Thank you in advance.
Radu
Everyone's tags (1)
273
