MODEM support across IP
I have a customer wanting to move modems from a PABX onto an IP infrastructure. No callmanager just gateways and FXS ports using H323, As anybody configured this succesfully without modem issues. Any tips would be helpfull.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: MODEM support across IP
If you have a really perfect connection between gateway, low delay and jitter, chances are that modem will work at moderate speeds like 14.4 or so.
Else, try configuring "modem relay", search CCO for the config guide.
1 REPLY
116
