Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Modify alphanumeric Sip Called Number
Hi everyone,
I'm trying to set up a sip connection between ITSP and my company. When I got incoming calls from PSTN to my online number this is showing a alphanumeric called number instead numeric as below:
May 18 14:33:29.248: //11085/45231A6AA411/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x485ED634
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 2721048092
Called Number            : companyname01
Source IP Address (Sig  ): 10.21.18.100
Destn SIP Req Addr:Port  : 201.86.87.2:5060
Destn SIP Resp Addr:Port : 201.86.87.2:5060
Destination Name         : 201.86.87.2
May 18 14:33:29.248: //11085/45231A6AA411/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g729r8
Negotiated Codec Bytes   : 20
Nego. Codec payload      : 18 (tx), 18 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.21.18.100
Source IP Port    (Media): 18952
Destn  IP Address (Media): 201.86.87.2
Destn  IP Port    (Media): 13506
Orig Destn IP Address:Port (Media): [ - ]:0
May 18 14:33:29.252: //11085/45231A6AA411/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 500
Question is, how I will route this call once the called number is alphanumeric?
Anyone else already fixed that?
Thank you and I really appreciate any help
Everyone's tags (2)
I believe you can do URI based routing on your dial peers.  Make sure you define the URI.
How I can do that?
Hall of Fame Super Gold
Re: Modify alphanumeric Sip Called Number
You need to ask you ITSP to send a called number.
532
