Community Member
Modify Ringback tone with cube ?
I have the design below
PSTN Provider <--SIP Trunk--> CUBE <--SIP Trunl--> CUCM8
Ringback tone for external callers is UK Tone. But we are in France. So we'd like French tone (like cptone FR on an E1 voice port)
Is it possible to modify that with the CUBE ? Or is it a job for the PSTN provider ?
Thanx for your help,
Bastien
1 REPLY
Community Member
Re: Modify Ringback tone with cube ?
Cube doesn't generate any tones. A rbt should be generated by PSTN-provider (or switch in the PSTN) with the mentioned command "cptone" in case of 183 Session Progress message or by originating VoIP equipment in case of 180 Alerting message
379
