Community Member
Modifying the UDP
I have created the UDP thru BAT,& in that i selected the Device Type as Cisco 7941, now i require to change the some of the user to use device as IP communicator, can any one suggest how can i make the changes for these users in device profile
I tried navigating thru' Device > Device Settings> Device Profile
Now when i try to modify the particular user, i am not able to change the " Product Type" , other parameters are changeable
Do i need to delete the profile & create ?
Please suggest
Re: Modifying the UDP
Yes, you need to delete and recreate the UDP to change the device type
java
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
146
