Modifying XMLdirectory
            I have a new 8.6 CM.  I want to change the xmldirectory.jsp file for the directory but Im not figuring it out.  Ive edited the file already to the way I want it, now I just want to upload it.  I figured out how to tftp it in OS administration but I have no clue what the path is to point the phones too.  Is there an easy way to do this?
You cannot modify any of the built-in directories (or any tomcat file for that matter) and replace it on CUCM, you need to put it your separate web server to host it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Bleh, ok then.  Thanks for the info
176
