Community Member
MOH and Conference
Hi there,
I got a question regarding this top:
If there is no Media Resource Group List (MRGL) has been assigned to Device Pool, IP Phone (Device) and User Device Profie (UDP), what will happen if a call has been put on "Wait" (MOH) or a conference has been setup?
Someone told me that the default MOH and Conference - configured on CUCM - will be used for these features. Is this correct?
I hope someone will give me more information about this issue. I find it a bit confusing. I already read the documents in SRND section about this issue but couldn't find my answer.
Thanks.
Ysana
1 ACCEPTED SOLUTION
Community Member
Re: MOH and Conference
Hi Ysana,
I believe this is indeed correct. What are you hoping to acheive?
- Service Parameters contains a default network & user MoH ID if this is what you like to change.
- Else if you want to completely disable MoH you cannot just avoid assigning MoH servers to MRG, you would need to create a seperate (unassociated) MRG so that ALL MoH servers are assigned to some form of MRG. If there is even a single MoH server not associated to ANY MRG it will be accessible by all!
I would guess this is possibly similar for CFB.
This is rather hard to explain but hopefully the description above can be understood.
Hope this helps.
Jani.
Community Member
Hi Ysana,
Hope this helps.
Jani.
Hall of Fame Super Red
Hi Ysana,
I agree with this assessment from Jani as well :) I just tested this theory in the lab and both MOH and Conference continued to work without any MRGL reference. Who would of thought?
Cheers!
Rob
124
