Community Member
MOH and Transfers not working through Inter-cluster Trunk between version 9.1 to 6.1.4
Hi All,
we recently upgraded a customer CUCM system from 6.1.2 to 9.1... it was a stepped upgrade, so in a lab environment we installed the customer version (6.1.2) and restored his data on my lab, then we stepped up to 6.1.4, then upgraded to 9.1..  then we took a backup of the cucm 9 version, installed ( for the customer and did a restore.. this worked perfect.
however, they had an intercluster trunk to another 6.1.4 CUCM.
so basically what exists now is two separate systems (9.1 and 6.1.4) , with a inter cluster trunk between them.  the trunk is up, i can call both ways through it, but MOH and tranfer isnt working... MTP on both sides are checked..
Im not sure if this is a compatibilty issue between the two versions or if im missing something... can someone assit if possible..
Surendra
1 REPLY
Have you already checked all the basics when MOH is not working??
MRG? MRGL? codecs? etc
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
135
