MOH Audio Source Redundancy
Is there a way to achieve moh audio source redundancy in Callmanager 4.1, example if audio source is unavailable on publisher, the moh should be played from subscriber
1 REPLY
Hall of Fame Super Silver
Re: MOH Audio Source Redundancy
You can create MOH Server for each CM server that has "Cisco IP Voice Media Streaming App" service enabled.
Then create another MRG referencing the second MOH server, and add it to the MRGL.
If you are using MOH Multicast you will need to assign different IP address or Port Number (depending on which method you use) for the second MOH server.
HTH,
Chris
120
