MOH CCM 4.1(3)
We have a CCM 4.x in our lab, change site and the MOH of telephony stop of the play. I restart de TFTP and MOH Server but nothing!
We are using CISCO2801 like MGCP gateway.
Peterson
MoH by default does not support G729, but you can configure CallManager such that it can stream G.729 as well. To do this you need to go to Service Parameters for Ip Voice Media Streaming Application and for the field "Supported MOH Codecs ", check G729 along with G711.
Hope this helps
8 Replies 8
thisisshanky
Level 11
Level 11
Did you change ip address on your callmanager ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
No it's same.
The ccm is tftp server too(lab)
The telephony is registered, the calls is ok.
I create a connection by ISDN by Siemens and the telephony "see" the telephony of Siemens side, but when I press hold button, only a beep sound.
make sure the MRGL, MRGs in use with the phones in question, have a MOH server listed.
Sankar Nair
See attachments
See attachments 2
See attachments 3
I found the problem.
The MOH don't play in G.729, only in G.711.
I don't know why! The MOH Audio Source is ok to G.729.
Hope this helps
